![]() | Home > Technical (L322) > Coolant level sensor |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
this shows a coolant sensor on a 4.4 petrol, not what you have but could it be the same? [half way down the page ]
Excellent write up but not the sensor I mean.
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
You probably already know this but the level sensor also checks the SG of the coolant - I assume your mix is correct? |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
EB yours might be |
There was a little cap on the tip of the sensor. When the sensor blew out !!!! of the tank when the transmission oil cooler went, I looked it and pulled a tiny rubber cap off. Since then the sensor is working (with clean proper coolant that is of course). MY 2010 5.0 SC Galway green and sand interior!!
