Home > Off Topic > Battery Charger Decisions.........
mjdronfield
My nearly 10 year old Halfords battery charger went pop this morning, so I've been looking about for a replacement.
I only use it to top the battery up every 4 weeks or do, as the Td6 doesn't get much of a run and I know how sensitive the old girls are with low voltage.
I have found the more modern equivalent of what I had, which appears to be this ;
http://www.halfords.com/webapp/wcs/stores/...55205#tab1
.........but, I looked for something a bit more robust, and found this ;
http://www.tantronics.co.uk/acatalog/Ring_...arter.html
which seems a bit better made, and has the added bonus that it'll jump start the Td6 if required.
The rub is - it doesn't look like it'll maintain the battery once charged, so I'll have to make sure I don't leave it on over the weekend etc, which I could do with the Halfords one.
Ignoring the price difference for the moment, I'm unsure what to buy.
I did have one of those cheap jump start power pack things a few years ago, but that was never any use and quickly ended up scrap.
Thought the Ring unit would also replace that..........
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #178054 17th Mar 2013 6:24pm
Charmer
I would recommend looking at CTEK Chargers.
They are very well made and reasonably priced.
Post #178055 17th Mar 2013 6:31pm
CTEK MXS 7.0 Thumbs Up
Fully controlled, you can leave it connected for weeks if you like.
Post #178056 17th Mar 2013 6:34pm
mjdronfield
Many thanks.
Have seen the 5.0 on Amazon at a good price ;
http://www.amazon.co.uk/CTEK-CTE-MXS5-0-12...amp;sr=8-1
but its on the edge with a Td6 battery and as you point out, it looks like the MXS 7.0 is the way to go.
Just need to find best price now.......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #178064 17th Mar 2013 7:07pm
Charmer
I got a MXS10 charger from these guys.
http://stores.ebay.co.uk/atozdiscounts4you...Z711547010
Very pleased with it, especially how quickly it charges the battery.
Post #178069 17th Mar 2013 7:20pm
mjdronfield
MMmmm seems shopping about, the MXS 10 is only about £11 more than the MXS 7.........
£104.25 delivered, and the cheapest I can see the 7 for is £93.44. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #178082 17th Mar 2013 7:54pm
I have a MSX7.0, no problem with it.
Post #178084 17th Mar 2013 7:59pm
mjdronfield
Many thanks.
Just ordered a CTEK MXS 7.0 for £92.95 delivered.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #178110 17th Mar 2013 10:05pm
The C-Tek MX5 is plenty for the TD6
Post #178111 17th Mar 2013 10:17pm
Martin
Site Admin
CTEK and one of my towing electrics adapters Whistle
http://www.disco3.co.uk/shop/index.php?act...oductId=45
(Although I can do an adapter for any charger)
Post #178121 17th Mar 2013 11:41pm
didnt know you did these Martin, i can see this solving the 'battery flat ,cant get into the fullfat' problems..
Post #178160 18th Mar 2013 10:42am
Martin
Site Admin
The same happens on the Discos so I don't see why not Smile
Post #178161 18th Mar 2013 10:48am
Works extremely well on an FFRR. Thumbs Up
Even if you don't have towbar and electrics it would be worth installing a stand-alone tow socket wired directly to a battery circuit and earth so that you always have a means of charging the battery even if locked out and your key doesn't open the drivers door.
Post #178162 18th Mar 2013 11:02am
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
I bought one of Martin's adapters for the Ctek and it just takes all the fuss out of charging the car
I reverse into the garage once a month and it's on charge in seconds. I can also charge on the drive with the lead passing under my garage door.
So much more convenient than popping the bonnet and fiddling around
Post #178177 18th Mar 2013 11:59am
Paul J.
I wish I hadn't seen this thread.
It has just cost me the price of the Ctek 10MXS and one of Martin's adapters Big Cry Laughing
Post #178275 18th Mar 2013 10:48pm
