Home > Maintenance & Mods (L322) > Non Land Rover brake discs
Page 2 of 3 <123>
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
King can you post the link for the eBay ones or let m know where you bought them please so that I can take a look...
Post #178134 18th Mar 2013 7:34am
I had the drilled and grooved one from Britpart (I think) good discs and worked well. Bought them for their anti corrosion coating to prevent the rears looking awful due to corrosion on the lip. They worked very well and looked more substantial. Downside was under heavy braking say (70>10 on a motorway slip road) you could hear a quite loud fluttering as the slots wizzed by the pad. Sounded like a warped disc but no vibration. Just my 2p worth. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #178138 18th Mar 2013 8:49am
Rich86
I emailed duckworths today and the guy there replied quickly as I was informed. For a full set of front and rear pads, discs and the sensors that they recommend should also be changed I was quoted just over £500. Obviously these are genuine parts which is really what I want to use with a 2.5 ton beast. Does that sound like a fair price and if not does anyone have any suggestions of other places that would be the same quality but cheaper?
Post #178240 18th Mar 2013 8:11pm
JIMMYM
Is that fitted?? Thought Td6 dics were about £60 a piece genuine and pads about £50 an axle set genuine. Would've thought petrol be similar??
Post #178260 18th Mar 2013 9:41pm
Rich86
No that's just to supply them. If you break it down the discs are £73 front £63 rear, pads front £62 rear £72 and the sensors are front £14 rear £12. When you add this up and add VAT...like I said if genuine parts could be sourced cheaper than I'd like to know.
Post #178287 19th Mar 2013 7:42am
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I got these and fitted them with no problem couple of weeks ago. Rear disks, pads and sensor for £70 plus £8 postage
http://www.ebay.co.uk/itm/110966541800?ssP...1439.l2649 2007 TDV8 Vogue SE Java Black
Post #178301 19th Mar 2013 9:26am
What did you pay for the fitting?
Post #178303 19th Mar 2013 9:30am
taskam
Did it myself and since it's such a pleasurable experience I don't charge for my time Wink 2007 TDV8 Vogue SE Java Black
Post #178304 19th Mar 2013 9:35am
i to brought both front and rear discs/pads of ebay at around £70 fronts and £80 rears...they came with mintex pads...
the only thing i would recommend to do is to paint the 'hub' bit as mine did go a bit rusty.. ... - .- -.
Post #178309 19th Mar 2013 10:00am
The cheaper the disc the quicker they rust...
Post #178311 19th Mar 2013 10:16am
Land Rover don't make discs or pads...
Post #178314 19th Mar 2013 10:42am
JIMMYM
I put Brembo discs on my Td6. Try www. performancebrakesonline.
Ferodo Premiers are a good pad as well - my LR indy uses them above genuine and normally a stickler for only using genuine parts.
Post #178372 19th Mar 2013 1:28pm
duckworthparts
Site Sponsor
all depends on age of vehicle etc, early front discs rrp £100+vat
Rich, you got forum discount applied Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #178374 19th Mar 2013 1:35pm
Well the hub part is the most annoying rust part and that can easily be painted.
The rest should come off nice and quick once driving Smile
I'd never go for drilled again after my coop experiences but dimpled and grooved only.
These are my fronts.
http://www.ebay.co.uk/itm/130723233589
And these are my rears.
http://www.ebay.co.uk/itm/130723241677
I use my FF offroad and don't hammer a lot of heat into the brakes from zipping to and fro but they still get warm.
The things are very heavy!
I have painted my hub sections on them but will do at some point if it bother me but i have bigger fish to fry at the minute and they aren't that easy to see anyway Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #178411 19th Mar 2013 4:23pm
Rich86
Dan, discount appreciated but still coming in at quite a bit. What is the discount exactly! Is it free postage? Just looked at thee bay link above and they only supply one wear indicator per pair of pads and disc. Aren't the wear indicators fitted on each hub?
Post #178413 19th Mar 2013 4:52pm
Page 2 of 3 <123>
