![]() | Home > Maintenance & Mods (L322) > L322 4.4 struggles to start when warm |
| JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833
A few things it could be, depending how good a scanner you have used ie isolating engine electronics etc but on the modded cars we work on, fuel line getting hot and fuel evaporating, fuel filter, petrol tank breather (if you take the cap off you will get a whooosh as the air is sucked in. Before looking at stuff like this I would get a proper diagnostic done. One day your life will flash before your eyes......................................make sure yours is worth watching!
| Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700
Trouble starting when warm is quite often a crank position sensor failing. |
Diagnostics should have thrown that up One day your life will flash before your eyes......................................make sure yours is worth watching!
A good diagnostics would pick it up but there is no guarantee anything is being stored .... I would not rule it out. |
Thats the prob when you have an intermittent fault, you can bet it wont do it when you need it to. One day your life will flash before your eyes......................................make sure yours is worth watching!
| 117 Member Since: 27 Jan 2012 Location: Bristol Posts: 25
I guess there's no harm in changing the crank position sensor, have been reading this morning and seems others have similar issues with this being the cause, any idea of cost of the sensor and how hard to fit?
From what I have heard they are pretty cheap and normally easy to fit. |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
With mine it was linked to dirty fuel system. I replaced the pumps, filter, cleaned the lines, tank and injectors as well as the inlet manifold.
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737
i have the exact same problem with mine even down to the fact if i press the gas pedal it splutters the same and starts, i have the faultmate system and no fault codes are stored?
Good to hear I'm not alone lol - I am going to try using premium fuel for a few tanks with some fuel system treatment and see if that helps - does yours do mostly short trips too? 2004 4.4 Autobiography - gone
All my trips are short and in very high operating temperatures with low quality fuel (likely diluted with all kinds of crap to make more money). Also the car didn't move for 2 years after being imported into Nigeria so silicone deposits may have played a role as well. MY 2010 5.0 SC Galway green and sand interior!!
i have already tried all the expensive fuels and additives and it did nothing to solve the problem, i experience the problem more when the weather is warm in winter i hardly notice the starting issue??
| GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836
Not on a full fat, but I had a leaking injector once which caused poor starting and eventually the cylinder stopped firing altogether
| PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877
I had the same problem on my X5
