Home > Technical (L322) > How to open the 'clamshell' to replace worn compressor.
Page 1 of 4 1234>
rgwatches
United Kingdom 2002 Range Rover Vogue Td6 Galway Green
Hi,
The compressor on my 02 l322 TD6 seems to be getting a little tired so I thought I'd try a new one (I have the RSW all comms and keep getting errors which indicate the compressor is on it's way out), however I cant seem to open the 'clamshell' to replace it.
Any help gratefully received.
Cheers
Post #178338 19th Mar 2013 11:55am
Unscrew it from the floor and turn it upside down. Thumbs Up
Post #178359 19th Mar 2013 12:57pm
rgwatches
The bottom seems bonded to the top, maybe I'm just being a tool, I've just done the discs and pads all round and the front 2 airbags so I have a modicum of knowledge.
Post #178360 19th Mar 2013 1:00pm
rgwatches
lol transpires I was being a tool, the foam insulation overflow made it look like someone had stuck them together!
Many thanks.
Post #178361 19th Mar 2013 1:08pm
Post #178362 19th Mar 2013 1:10pm
Mine was similar, had to prise the under cover off with a large screwdriver. .
Post #178399 19th Mar 2013 3:37pm
rgwatches
Thanks, I've actually installed a new piston into the compressor to see if that helps before diving into a whole new unit, height change etc seems quicker.
I'll see if the dreaded error comes back....
Post #178409 19th Mar 2013 4:21pm
Where did you acquire the piston?? Previously..
Post #178417 19th Mar 2013 5:00pm
rgwatches
Got it from flea bay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...TQ:GB:1123
Post #178424 19th Mar 2013 5:07pm
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
That fitted? be interested to know how you have got on since. I ended up replacing my compressor rather than refurb. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #178443 19th Mar 2013 5:32pm
rgwatches
It did, it's installed and working but I haven't driven it long enough to know whether I'll get the error back (less than 10 miles).
The old one was very worn so it may do the trick, I suppose it depends on how worn the bore was.
I'll drive it a bit more and report back.
Post #178463 19th Mar 2013 5:54pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
The error will come back soon, because only to change the piston ring is not enough, because the cylinderhead becomes bigger and bigger inside, the new ring will help for some month, it is like new brake pads on very old brake discs..., also you need to change the dryer patrone, or to dry it from inside like the one genial guy with his wiki-story!! Had buyd also this new piston ring, is good quality, but not strong enough for the old cylinderhead.
Best regards from germany, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #178487 19th Mar 2013 7:14pm
rgwatches
Thanks, for £35 and 30 mins work I thought it was worth a punt, will advise just to see how longs it lasts.
Post #178488 19th Mar 2013 7:15pm
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Have read this with interest,as i have noticed my compressor struggles sometimes, my Hawkeye tells me it is not producing enough air, so have just ordered the piston ring and hope it will sort me out .
However in the event of no change then URI i will be begging.lol
Cheers Piers
Post #178623 20th Mar 2013 1:50pm
rgwatches
Well I've done another 30 or so miles and no fault yet, and like I say it raises and lowers a lot quicker.
I think for that sort of £ it's worth a go, even if it gives me another 6 mnths or so I'll be happy.
It's quite an easy fit but if you get stuck give me a shout.
Post #178625 20th Mar 2013 1:58pm
Page 1 of 4 1234>
