Home > Maintenance & Mods (L322) > Rear wiper arm
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Rear wiper arm
Just replaced my wiper motor and noticed the the cap on the motor end of the wiper arm refuses to stay firmly over the water outlet of the motor spindle. The result is the water does not spray it dribbles down the window. Is this the sign of a worn arm that needs replacing or is there something else I can do to fix it? "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #177636 14th Mar 2013 8:08pm
Charmer
Unfortunately I think you may have snapped the end of the spindle that goes into the end of the wiper arm.
I have done the same but found that more water is now dribbled onto the rear window and it cleans the window better! Laughing
I am going to live with mine until the wiper motor goes bang!
Post #177640 14th Mar 2013 8:29pm
MrP
No that is not snapped as this is a brand new wiper motor. When I refitted the arm and gently pushed the end cap of the arm onto the spindle it would stay then pop back a bit thus not making a seal and allowing the water to slurge not flow into the jets. "On first name terms with my local Dealer......now."
Post #177644 14th Mar 2013 8:34pm
Charmer
Did you clean the rear wiper arm when you changed the motor?
If the two jet holes are blocked this could be your problem, the added pressure could be unseating the cover and causing the dribble.
Post #177649 14th Mar 2013 8:51pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Re: Rear wiper arm
MrP wrote:
... The result is the water does not spray it dribbles down the window.
Hmmm ... mine does this, thought it was normal
Post #177656 14th Mar 2013 9:04pm
MrP
Wiper arm was cleaned and when you first push the end cap over the spindle it sprays water nicely but after a short while it lifts a bit and water then just dribbles out of the base of the wiper arm end cap instead of the jets. It's as if the end cap spring is not strong enough to hold it tight to the top of the spindle. "On first name terms with my local Dealer......now."
Post #177660 14th Mar 2013 9:26pm
aneurysm1
2010 Range Rover Autobiography TDV8 Cairns Blue
My rear wiper doesn't seem to work either, I'm wondering why?
Post #177680 14th Mar 2013 10:55pm
MrP
Problem now fixed - new wiper arm with better fitting end cap has done the trick - washer now sprays nicely over the rear window rather than just dribble. Smile
Another FF Job complete. "On first name terms with my local Dealer......now."
Post #178440 19th Mar 2013 5:29pm
MrP
Post #178442 19th Mar 2013 5:30pm
Katash
Regarding this, by 'spray' do you mean like a fan shaped spray? .... Not sure if mine is correct or not really, originally mine was just a dribble and took ages to come out but after I changed the NRV inside it now squirts out quite alot (looks normal to me but nothing to compare against) but its not in any spray (fine mist) pattern its more like a hose jet now.
Post #178444 19th Mar 2013 5:33pm
MrP
When I said spray I should have said squirt - the old wiper arm didn't fit over the washer pipe properly (firmly) so water just escaped around the wiper arm end cap - the new arm fits tightly on the washer nozzle and I now get two jets of water down the rear screen. "On first name terms with my local Dealer......now."
Post #178452 19th Mar 2013 5:42pm
Katash
Hmmm ..... not sure if mine is right or not then then but to be honest I don't think its worth worrying about, before I changed the NRV there was a long wait before the water came out now (right or wrong) a sufficient amount of water comes out to clean the screen so I'll leave it I think.
Thanks
Post #178458 19th Mar 2013 5:45pm
