![]() | Home > Technical (L322) > Torque convertor problem |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
It sounds like it needs replacing |
FleXzoR Member Since: 28 Jan 2013 Location: Bruges Posts: 44 ![]() ![]() ![]() |
I did a stall test and the engine stalls at about 2400rpm's, so i think my TC is ok? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
Unfortunately, failure of the torque converter lock-up clutch in the GM 5L40-E transmission is a very common problem with the TD6 L322.
Is this an expensive part? Much labour involved?
Do you feel a vibration at lock up?
The lock-up clutch fails through low engagement pressure caused by spool/bore wear in the valve block/pump housing (which allows leakage). Replacing the torque converter would only be a temporary fix because the root cause hadn’t been addressed. You really need to check your fluid for metallic contamination because if the LUC has worn through its lining I’m afraid the rest of your transmission is about to go the same way as it’s effectively running in grinding paste.
Thanks for all replies!
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
If you carry on driving, you are just making the problem more and more expensive to fix. |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I would advise to stop driving the vehicle and get the gearbox rebuilt, this means TC, valve block and clutch plates...plus get the oil cooler replaced. The TQ could fail totally and leave you stranded, but the worst case is damage to the gearbox casing, which means a whole new gearbox!
Valve block has been replaced and problem seems to be solved. (torque converter was only 4000km's from new)
