Home > Maintenance & Mods (L322) > FFRR '02 Rear Suspension Dismantle & Rebuild |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6397 |
Been gathering parts and bits and pieces for this for a while, and some leave from work has provided me with the opportunity to dismantle my rear suspension and replace all the bushes, tie rods and links. Airbags and dampers are OK, but these are the easier items to remove!
18th Mar 2013 8:17pm |
1. Get the car in the air.
21st Mar 2013 9:11am |
Got an earlier start today, out there by 0830
21st Mar 2013 9:12am |
Had a few other real world things to do today so not a great deal done, but time consumed by problem ball joint!
21st Mar 2013 9:13am |
Bush pressing kit arrived today, so set to work on pressing out and replacing all the bushes on the hub, the arms and the subframe. It is a lot bigger than the ebay picture conveys, ( I put a standard Stanley Philips screwdriver in shot to give scale) case is @ 48cm wide by 40cm deep, and weighs @ 40lbs. As impressed as fisha was - the mutts nuts!!
21st Mar 2013 9:14am |
1. Finish Removing Lower Arm Bushes
1. Hub Bushes Replaced
Bloody cold today, snowed on me several times
21st Mar 2013 9:15am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Joe your a legend I kind of follow what your doing as it seems complex but I admire your persistence with such a big project Present :2008 TDV8 HSE
22nd Mar 2013 11:04pm |
Took a day of rest today, fed up with spending all day on my knees in the freezing cold.
25th Mar 2013 12:51pm |
Damn I have an air leak.
26th Mar 2013 5:08pm |
Took on the Rear Right today with good weather promised for the weekend. Didn't get started until @ midday and finished @ 8pm. Most items appeared to undo much easier on this side as compared with the rear left, or I've got stronger! I took quite a different approach this time, based upon what had been learned from the other side.
6th Apr 2013 11:31pm |
Nice sunny morning 10 am start!
7th Apr 2013 8:29pm |
MON
9th Apr 2013 8:15am |
