![]() | Home > Technical (L322) > RR S/C Suspension v's TDV8 |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
No, they changed in 10MY and on i think where it got the adaptive cornering guff to help keep it flatter |
| carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717
So its the same set up therefore same ride on the S/C compared with the TDV8 for 2009 until the newer one in 2009? |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
The suspension on my Mdl 10 TDV8 is pure pish compared to my old 06 SC |
Sorry, do you mean rubbish and the S/C is better? The crying has thrown me a little |
Yeah the suspension set up on my TDV8 is way too floaty at times , the SC set up was a helluva lot better … |
| E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513
Funny enough I read this only this week on SC suspension ??
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
"On the supercharged model, the suspension was adjusted to provide flatter cornering but at the expense of an inch or so of articulation, which will slightly restrict ultimate off road performance."
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
for 'normal' off road performance the s/c will not suffer at all, member justinp brought his 2006 s/c to salisbury plain and he had no problems 'doing' what my td6 and member Doms 2007 tdv8 did... ... - .- -.
TBH the wheel and tyres will affect it just as much as the TDV8 will be on 19's and the sc on 20's which have a slightly stiffer sidewall with their reduced height and 20's being more road biased tyres in general in standard fitment. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
there are probably more tdv8's on 20'' tyres than 19'' looking at the ebay/autotrader/ps ads i have been perusing lately....
Same tyre model will be stiffer in 20 than 19 as there is less of it to move |
the difference in side wall dimension between a 255/50/20 and a 255/55/19 same make tyre/type is 13mm so your cardboard theory is very inaccurate.
indeed this is well documented, but the reason the td6 gets the vibrations is because of the torsional oscillation causing a driveshaft resonance..this only happens on the diesel and not the petrol model.... ... - .- -. Y. O. L. O. . |
The analogy is crude but an affective one.
i agree with that,
| All times are GMT |
