![]() | Home > Wheels & Tyres > TPMS - replacing the battery? |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Unlike most, my TPMS works fine!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35763 ![]() ![]() |
if its not broken dont try and fix it... |
ok, you win.. |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
Decided to have a look. After some digging found that it's a coin cell, CR2450S, soldered to the board as you would expect.
Thanks Taskam, good write-up. I wish I got that lot that was on ebay the other day, just for next time when my tires need changing (should be a while though). MY 2010 5.0 SC Galway green and sand interior!!
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
is there a way of testing to see how much life is in the battery?
The potting compound is reasonably soft, so you could probe down onto the two pads that the battery is soldered to and measure the voltage that way.
i'd google that one.. but, is this not a lot of hassle if the new valves can be brought for £30'ish.. ... - .- -. Y. O. L. O. . |
Agreed, provided that they self program, it makes sense to replace. The valve stems get corroded after a few years anyway. 2007 TDV8 Vogue SE Java Black |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
Mine reprogrammed themselves within about 7-8 miles.
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
Having just done this....
Thank you E 4 Guy |
