![]() | Home > Technical (L322) > RR S/C Suspension v's TDV8 |
Found this on the RRS Supercharged but I sure FF Supercharged has similar:
Its hard to get any real evidence other than the electric locking diff on the Supercharged.
Higher air pressure in the airbags just makes it lift higher thats all, the pressure stays the same unless the weight increases.
And the e-diff was an option on TDV8's and so on, though if fitted to all SC's would help them get off the line and keep the power down in corners more. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
I am in agreement that the 2007+ Supercharged appears to have the same suspension set up to the TDV8 and 2007+ AJV8. ![]() |
I think I may have driven more than a few 2007+ Supercharged, TDV8 & AJV8's..... Mick's Supercharged was a 2006 ![]() |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
As above, the TDV8 has different front struts from what I can ascertain, presumably because of the additional weight of the engine.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
The electronic rear differential was also available on the normally aspirated V8 as an option. I've got a US spec V8 HSE LUX 2008 and my mechanic and I were both surprised to find it had one. He found it while doing routine maintenance and I found it when offroading and the info screen showed it was there and locked. We both thought it was a nice surprise when we compared notes. Later, I found it on the original build sheet.
I just lowered mine with IID - handles as well as my old 4.2SC and 5.0SC did ...... in fact, better. Land Rover Addict
2006 4.2SC's with the normal handbrake (not e-brake) do NOT have the rear e-diff. Land Rover Addict
As far as I can tell my 2006 SC does not have the rear e-diff. When I try to talk to the ECU with the Faultmate it says not installed. MY 2010 5.0 SC Galway green and sand interior!!
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Just to revive this, i have an opportunity to buy a 10 plate TDV8 Vogue, am i right in thinking it has adaptive dynamics being the facelift car?
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
I guess your choice of model depends heavily on what is the most important criteria to your style of driving.
The 2010 facelift cars have adaptive dampers (wires coming from the front strut tops). Anti-roll bars are the same, the heavier engine and different front struts of the TDV8 will mean it won't drive exactly like a contemporary Supercharged one. No L322 is going to drive like a Cayenne - if you need a (rough) approximation of that, get a Sport. If you're lowering ride height, presumably you're also correcting alignment? |
