![]() | Home > Technical (L322) > Smokey 4.4TDV8 |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Is it a drain or a feed problem ??? One day your life will flash before your eyes......................................make sure yours is worth watching!
I have a mechanical engineering background and quite some hands on machining experience (cars, bikes and guns) and I don't like it either, at least not the work done by a "normal" car mechanic. If it is a properly trained machinist, that know how to drill and tap and make sure no metal goes in, fine.
rjbax1978 Member Since: 07 Oct 2012 Location: northampton Posts: 16 ![]() ![]() |
I think it's a drain issue from turbo back to the sump 2011 TDV8 Galway Green Vogue Se
So they are not drilling into an oil way !!! The drain will only be back into a sump so i cant see the problem, I take it they are saying the oil cannot escape the turbo center cartridge fast enough and is backing up past the seals, we have the same problem on the very large turbos we fit to the Jap cars I build and they have to have a monster size drain to get the oil away. One day your life will flash before your eyes......................................make sure yours is worth watching!
I don't know the exact position of the pipe but from what I understood its a drain back to either block or sump
Last big turbo i installed was a GT28RS |
RFAA you have had exactly the same smoke pattern as what I am experiencing
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 508 ![]() ![]() ![]() |
RFAA and rjbax, I've just seen the same on my car today. I notice it once last month and thought it was just the DPf cleaning out. But saw the same today and exactly as RFAA described. Did they drill as you were told and is the problem fixed? My cars due to go in soon to fix a few other issues so what sshould I tell them to make sure they fix this as well? Is it worth getting the DPf and turbo replaced as well now to avoid a problem later on? MY11 Vogue 4.4 TDV8 - "African Queen" |
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 ![]() ![]() ![]() |
It's a job with a 9 hour book time. Diff has to be removed and transmission cooler pipes. Problem relates to a pipe being ineffective in draining oil back to the sump. |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
Does anyone know if there is a VIN number range of effected cars available? 4.4 TDV8 Vogue Baltic Blue MY11 |
![]() here's to hoping that my issue is different and substantially minor.. ![]() wslr - did you have this problem with your car as well? has anyone had any subsequent/consequential issues after this fix? and is there any possibility this could relate to head gasket issues (in the alternative)? MY11 Vogue 4.4 TDV8 - "African Queen" |
d3rm0 Member Since: 12 Feb 2012 Location: UK Posts: 442 ![]() |
Had the fix last week on my 12M.Y. It took the dealer 16 hours to complete the mod |
Shalz The dealers had mine for 13 days to fix its quite an involved job apparently and requires the front subframe and suspension legs removing to allow better access, the time on topix is unachievable in the words of the dealers!!.
Thanks all for your replies...
