|  | Home > Technical (L322) > Steering column tilt problem |
| Scorchio Member Since: 28 Apr 2010 Location: Staffordshire Posts: 24      |
 Just bought a 2003 Vogue 4.4 ... will post pics after I've given it a nice polish !
|  5th May 2010 12:04pm |
| DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148      | Odds on, its jammed not broken. There is a nut on the end of the worm gear that tightens and then prevents it from turning.
|  5th May 2010 5:09pm |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | Rather than start a new thread on this - does anyone know how to lubricate the column? Mine makes a noise when its retracting when switched off. Sounds like it needs oil. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded | ||
|  5th May 2010 7:06pm |
| Scorchio Member Since: 28 Apr 2010 Location: Staffordshire Posts: 24      | Oh forgot to mention - mine does this too ! 2003 Vogue 4.4
|  5th May 2010 7:25pm |
| SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77      | I used a long artist's brush about 1/4" wide with grease on it and lubricated the screw mechanism. Noise gone.
|  5th May 2010 9:09pm |
| SteveNorman Member Since: 18 Sep 2008 Location: somerset Posts: 17    | If lubing the screw thread doesn't work, try a small squirt of WD40 (or teflon spray) on the bit where the shaft turns by the motor end, (you can see the spindle spinning round there), as these tend to cause the eek, eek eek noise. You know when you have found the right bit as the noise goes away   | ||
|  6th May 2010 11:02am |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383    | This is a great post guys but some pictures would be very useful for everyone...anyone got any of the work? Discovery 4 HSE
|  6th May 2010 5:36pm |
| CyberMrT Member Since: 26 Mar 2010 Location: Stratford upon Avon UK Posts: 60    | This is not really maintenance but shows what happen when mine actually broke, the metal tab snapped  | ||||
|  6th May 2010 6:23pm |
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325    | Funny this thread should come along, I freed mine off last week, I forgot to take some pics as I was going to do a 'how to'.
|  6th May 2010 9:05pm |
| doublejay Member Since: 08 Nov 2009 Posts: 131  | ..wait, are we saying there;s more adjustment available if you tweak underneath ? | ||
|  7th May 2010 8:18am |
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325    | Don't know abuot extra adjusment, but if I lower mine right down, it crushes my legs  | ||
|  7th May 2010 2:48pm |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | I'm being v lazy now- how do you get at the mechanism to lube it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded | ||
|  10th May 2010 2:15pm |
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325    | There's 3 torx screws on the under side of the shroud, the top 2 should be esy enough to get at with uninsulated torx screwdrivers, but the one at the bottom by itself is tucked right in, I found a couple of 3/8 extensions from a socket set with a torx bit on managed to reach it no problem.  Once the screws are out, lift the top section up and outwards (If I remember rightly!!)  The lower one will drop down too, then lookin up from underneath the steering colum, the spindles are right infront of you.
|  10th May 2010 9:24pm |
| Posting Rules
