![]() | Home > Technical (L322) > Brembo brake upgrade |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
Yep, fitted a brand new TDV8 brembo setup recently. Job went very well, due to the callipers never being fitted before I had to run a tap through the threads and I also bought the wrong discs first time round. All in all it was a cheap and very worthwhile mod, breaks are much sharper and have a great feel. Don't expect racing performance though, they can't change the laws of physics.
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Steve, thanks for the info. Would these be the same for my standard 52 vogue v8 petrol? |
someone will confirm but yes they will fit the same. Only difference between TDV8 and SC brembo callipers is the colour (grey or black) currently your car has single piston callipers with 345x30 discs. |
Also make sure you have 19"+ rims |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7935 ![]() ![]() ![]() |
Do you need to have 20" wheels ?
Ah, beat me to it !!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
Yes Brembo's will fit on all FF's but the later (bigger 6 pot) Brembo's with Range Rover written on them for the 09> MY wont fit the earlier models as the bolt/mounting holes are too small on the 02-08 hubs...
I'm pretty interested in this upgrade.
I would upgrade to Brembo all round as there's a noticeable improvement apparently.
TtheArab Member Since: 26 Apr 2013 Location: Dunblane, Scotland Posts: 89 ![]() ![]() |
Just managed to pick up calipers. Anybody have part # for dust shields ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35742 ![]() ![]() |
http://www.fullfatrr.com/forum/topic17841.html
Thanks. Found part # on microcat by removing my VIN and just scanning SC profile. Now ordered alongide sensors. Will refurb Brembo's and then fit these when I swap out the 18" alloys later in the year. Good to have it all there and ready.
Brembo don't do standard rear calipers... IE if you have an SC or TDV8 with Brembo's, they are only the fronts ![]() |
Thanks Craig.
