Home > Technical (L322) > How to open the 'clamshell' to replace worn compressor.
Page 2 of 4 <1234>
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Thanks , I am pretty sure that this is the fix i need.
Cheers Piers
Post #178630 20th Mar 2013 2:15pm
rgwatches
United Kingdom 2002 Range Rover Vogue Td6 Galway Green
Just a quick update, done a few hundred miles now and the no dreaded EAS fault as yet, this is the longest I have gone without the 'air suspension inactive' message.
Seems to be doing the job thus far.
Post #179099 22nd Mar 2013 3:37pm
I think ou will be surprised how long it lasts. I stripped mine and sanded the sealing face on my old ring and applied some vac grease and mine was still going strong before I sold it so was ok for about 8months. You have new piston rings so I guess will last even longer! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #179103 22nd Mar 2013 4:04pm
piersie
Okay my piston ring arrived this morning,so went and fitted it,it was simple after reading this thread , and the only problem i would of had is removing the clam shell.
And after fitting i am now reaching off rd height easily,whereas it struggled before,so thanks guys and fingers crossed.
Cheers Piers
Post #179115 22nd Mar 2013 5:04pm
rgwatches
I had a height issue (front way to high, back a little high) but could not re calibrate with RSW all comms due to the lazy pump, now since the new piston ring I have successfully re calibrated and all is working perfectly!
Post #179641 25th Mar 2013 2:02pm
muffster
2002 Range Rover Vogue Td6 Java Black
Hi mate, I'm just about to do exactly the same job.
Could you please tell me:
How did you disconnect the air hose to the compressor from the coupling/union t-piece that it goes to. Does it just pull out?
And, did you have to get the error message on the dash reset after?
Thanks.
Post #179685 25th Mar 2013 7:05pm
rgwatches
Hi,
All you have to do is push the brass\steel part down and pull the pipe out.
I did, I have the RSW all comms to do resets, good bit of kit worth buying.
Post #179694 25th Mar 2013 9:02pm
muffster
Great thanks.
Hopefully the kit will come tomorrow and I can crack on.
Thanks.
Post #179701 25th Mar 2013 9:43pm
muffster
Hello again mate.
just fitted the kit today and dried out the air drier, cleaned the springs up etc.
Put it all back together and... nothing.
When i started it up i expected to hear the compressor and be able to adjust the height but nothing, it's exactly the same as it was.
Do i need the do a battery re-set?
Thanks.
Post #179922 27th Mar 2013 1:46pm
rgwatches
Afternoon,
What error have you got?
If the system is inactive you'll need a reset.
Post #179924 27th Mar 2013 1:49pm
If I'm not mistaken, to avoid any problems with fault codes when working on the compressor it is advisable to disconnect the battery before disconnecting the power to the compressor.
When the compressor is reconnected, reconnect the battery and move the steering fully lock to lock.
Post #179935 27th Mar 2013 2:24pm
rgwatches
I didnt personally do that and had no issues (I did do a reset with RSW prior), but it seems like a sensible precaution.
Post #179938 27th Mar 2013 2:32pm
muffster
Gents,
Thanks for the quick replys.
The error i have got is the inactive message on the dash. I had the codes read at an indy who confirmed it was the compressor.
I wasn't sure from the jist of the posts if using the repair kit would make the system operable or would i need to have it reset and code cleared to make it work.
So will book it in hopefully it will have done the trick.
I didn't disconnect battery as reading other posts it didn't seem needed.
I was just a bit surprised that the compressor didn't react at all when i turned the car back on.
Many thanks.
Post #179979 27th Mar 2013 6:08pm
rgwatches
Have you disconnected the battery, leave it 15 mins, then reconnect and move to wheel from lock to lock a few times as previously suggested?
If that doesnt work you may need to have the fault cleared before it will fire up again.
Post #179981 27th Mar 2013 6:10pm
muffster
Hi mate,
Just tried it, no joy.
it's going in tomorow so fingers crossed.
Cheers.
Post #179995 27th Mar 2013 7:23pm
Page 2 of 4 <1234>
