Home > Off Topic > Advice needed on home audio setup please
Andy
I have a pair of Bose Acoustimass speakers which I used to have connected to an old Pioneer stack system. Since putting the Pioneer into retirement, I've got no way of powering the Bose as they need to be connected to an amp.
Can anyone recommend a decent amp that won't take up much room for underneath the TV, so I can take a feed from the TV to the amp, then out to the Bose speaker module?
ta 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #17763 3rd May 2010 8:27pm
doublejay
bit of minefield noddy without more info....budget, connectivity requirement etc. I will say that the small units from Denon or Onkyo a very well thought of and not a lot of dosh
http://www.richersounds.com/product/mini-h...o-dm37-sil
http://www.richersounds.com/product/mini-h...-cr435-blk
If you need "flat" unit - none of these would let you down and receive decent reviews all round.
http://www.richersounds.com//productlistma...LL/price/2
Post #17774 4th May 2010 9:41am
Andy
I'm led to believe it needs an amp to run. There's no power supply to the sub module ( unlike later versions). It just has speaker inputs which are the clamp type. It might work, but I've never tried it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #17844 4th May 2010 9:54pm
ukrangie
An Onkyo amp is great value.
£199 - http://www.froogle.richersounds.com/produc...xsr507-sil
£499 - http://www.froogle.richersounds.com/produc...xnr807-blk
Visit AVForums.com. There are a lot of great guys with a wealth of knowledge. Paul
Twitter - Facebook
Post #17887 5th May 2010 8:46pm
daveo
hi noddy, how many speakers do you have, you say a pair, and do you have the base unit to go with them
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #17894 5th May 2010 10:42pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Noddy, which if they're not active Acoutimass speakers (hence why you need the amp), then could do with knowing the model versio or the RMS & peak power handling along with the impedance (i.e. 4/6/8 ohm) etc. of the speakers. It's then easier to match an amp to them with this info. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #17993 9th May 2010 12:35am
Andy
How do I find that info out? Is it on the bass box? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #18056 10th May 2010 3:17pm
RRVSE
Speakers normally have a model number on the back on a sticker, often near the terminal connectors. If it doesn't have the wattage and impedance, can usually get the specification by googling the model number. Steve
Post #18061 10th May 2010 4:28pm
