![]() | Home > Technical (L322) > RSW Allcoms won't clear Airbag light FIXED |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2946 ![]() ![]() ![]() |
I've been sat here now for ages clicking on Clear Faults and the airbag light will not go out.
Bump |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35703 ![]() ![]() |
the only thing i can think why its not clearing is that there is a faulty airbag or airbag sensor...it could be a faulty seat occupant sensor like mine had... ... - .- -.
Where's that located? |
mine was the the passenger seat sensor [under seat cover] the airbag light on the dash would flash as the occupant moved in the seat ...check the connections under the seat first...
Battery is new. Swapped it this morning as it had a 5 yr warranty.
i'm stumped with that fault code....i wonder if it refers to the RSW and not the range and thats why you cant clear the error..
Spoke to a technician at Land Rover dealers yesterday- he said a common problem on this model year was fractured wiring in the seat.
that was my problem but an intermittent one ..my replacement occupancy sensor was around £100 retail which i didnt pay as mine was still under warranty.. ... - .- -.
I've just removed the seat and checked the connections. I've belled all of the plugs out and they all bleep, so no problems there.
it sounds like you might have to get a proper garage jobby to find the fault code to trace the error..but, before you do that i would do a battery disconnection again , worth a try .. ... - .- -.
Can't do that- they check to see if it comes on when they turn the key, then to see if it goes out. |
how about the steering wheel air bag, i have spoke to story and he is getting back on with the all comms software |
On some forums, the suggestion points to the srs ecu. Will Testbook confirm this as I have a local specialist garage that will run a check FOC. |
