![]() | Home > Maintenance & Mods (L322) > MPG after switch to K&N air filter |
| MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471
I am assuming the electronics have got very confused (I hope they have) as since switching to the K&N air filter my MPG has plummeted to 13 or 14 MPG where it was at 20 with the actors setup.
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
Do you mean replacement filter, or you've fitted a cone filter? In which case what have you done about the secondary air injection system? Also, how have you ensured it's sucking in cold air, rather than hot engine bay air? Compromising either of these systems will give you poor fuel economy. |
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528
Was the battery disconnected at any point ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
I have fitted a cone filter yes and all I have done for now is locate the filter at the end of the tube where the old filter was located. "On first name terms with my local Dealer......now."
It might be worth confirming your MPG figures with a brim to brim test. Just to see whether it's giving you incorrect information... |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Cone filters can have an adverse effect on the engine performance. Years ago I fitted my Suz GS1000 with cones directly on the carbs. After a lot of tinkering with the jets, I finally got the mixture right. It didn't have its full "workable" torque range though.
Yes I zero'd the mpg figures in the on board computer. The reason for the K&N install was that I will be doing a 2006 facelift shortly and wanted to get the filter bit done and out of the way. The choices as I see it are a) stick with the K&N and try to sort out what it's doing or b) do the mod I have read about to the original filter housing and go back to OEM layout.
| wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77
In my opinion, fitting a k&n filter or similar should have no effect on mpg on a standard fuel injected engine. the air flow meter monitors the volume of air entering the engine and the lambda sensors on the exhaust monitor the air/fuel mixture which will adjust the amount of fuel the ecu gives the engine therefore the engine should always be running at its optimum air/fuel ratio no matter what filter you have. the mpg difference is probably because you reset your mpg calculator. give it time to average itself out and i would imagine it would go back to the same. '04 td6 se
| klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210
Are you sure your original mpg figures are correct 20 mpg sounds very good , the most I ever got out of mine was 18 mpg and that's driving like a Sunday driver with an egg under the throttle , normaly I get 16 at best 12 at worst |
Fairly sure yes - regularly reset to check it - I do a lot of motorway miles in the FF averages out at about 19.1 and occasionally the long term average would be 17 if I'd done more trips around town.
check out my post in this thread
that was the mod I read about - did you ever take any pics of the result? "On first name terms with my local Dealer......now."
not sure i may have will have to check it out, as i said it can be done its very tight for space the air filter housing is easy the intake pipe from the inner wing is the bitch , on reflection i guess you could use some ali flexible duct which would be easier to shape |
| JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833
Interesting what you say about smooth vs turbulent as the last thing you want when porting a cylinder head is a smooth mirror like tract, they are intentionally roughed up to improve air flow..........................think golf ball !!! One day your life will flash before your eyes......................................make sure yours is worth watching!
| All times are GMT |
