Home > Technical (L322) > How to open the 'clamshell' to replace worn compressor.
Page 4 of 4 <1234
muffster
2002 Range Rover Vogue Td6 Java Black
No, none at all. though the air drier was very damp so I gave it all a good going over with heat gun to dry it out.
Post #180499 30th Mar 2013 8:36pm
If you wish to test the compressor you can un-plug it and put 12V directly onto the terminal that the large dia Red/ White cable goes onto and earth the brown cable terminal. Need a decent dia cable and you will get a few sparks as you touch the terminal. Very Happy
Post #180500 30th Mar 2013 8:41pm
muffster
Tried it today and yes the compressor runs. Let it run for a while in short bursts so as not to burn it out but it didn't lift the suspension. it's as if its not man enough to pump it up.
Post #180582 31st Mar 2013 3:25pm
rgwatches
United Kingdom 2002 Range Rover Vogue Td6 Galway Green
I know it's a pain but you really need the specific fault code to narrow the search otherwise it's a very long process of elimination.
Perhaps someone local has a reader you could borrow?
Post #180586 31st Mar 2013 3:47pm
Sounds like its not pressurising, if the compressor is running and you are getting airflow out of it then the air needs to go somewhere, it obviously isn't going into the reservoir or springs.
Have a look at rave as it lists all of the individual components and you can get an idea where the air could escape. There is nothing that can't be fixed with a hammer😜😜
Post #180593 31st Mar 2013 4:57pm
muffster
The garage didnt actually give me the fault code, the read out just said EAS reservior static when filling.
Post #180707 1st Apr 2013 2:35pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
First look in your EAS compressor at your dryer patrone, and also at your valve for the going out pressure, then change your reservoir-sensor RQH000130, (best price at island 4x4, 38,00 GBP + VAT), some guys in USA want 100 $ !!!!, clear the faults, and all becomes good... (of course your pipes, connections and struts must be 100%) L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #180709 1st Apr 2013 2:44pm
rgwatches
Just a quick update, compressor still doing the job and no dreaded EAS errors.
Post #192145 5th Jun 2013 9:52am
Page 4 of 4 <1234
