Home > Maintenance & Mods (L322) > centre console 2004
daveo
centre console 2004
hi does any one know if the centre console sides come off, these are the side panels that run the length of the centre console, want to get under the gear selector but it looks like the full console has to come out..need to get to the EWS to write a new key for the car V8 facelift Range Rover Autobiography 22" wheels.
Post #181142 4th Apr 2013 12:17am
Looking at RAVE (and although it is not clear if the side panels are joined at one end, e.g. its all one piece), it looks like you will have to do most of the work of completely removing the console before you could get at the fixings that hold the side panels in place, so reckon that complete removal will be as easy or easier than trying to get the side panels off. That said, whether you can still do what you want to do with the console out of the way ? .
Post #181143 4th Apr 2013 12:32am
daveo
thanks, it appears that the console is ifxed right at the front, i have removed most of the fixings and the console pivets forward ,lifting from the back, i can get it to about 45 degrees forward but still cant get the front to unclip, V8 facelift Range Rover Autobiography 22" wheels.
Post #181196 4th Apr 2013 10:45am
maybe the center dash console has to come out Dave to access whatevers holding it.. ... - .- -.
Post #181199 4th Apr 2013 11:03am
SteveMFr
Site Sponsor
It's been a long time since I did this, but IIRC the console is screwed to the center dash panel. Remove this (screwed to the dash cross bar or middle dash pad by removing the 2 center facias (EAS & climate control)) and you should get to all.
Either way not too difficult or even very time consuming.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #181290 4th Apr 2013 5:57pm
