Home > Maintenance & Mods (L322) > Bluish Smoke From under the Front
Page 2 of 3 <123>
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Did you run over wackyjim, who was smoking a big one at the time?? Whistle
Post #181265 4th Apr 2013 4:00pm
this is from the wiki and it refers to the td6 but i'm sure yours will be the same,
Additional Heating
On Td6 models, additional heating reduces the heater warm-up time and is also used to maintain heater performance throughout the drive cycle.
Post #181267 4th Apr 2013 4:11pm
Martin
Site Admin
FBH is triggered automatically to help coolant warm-up for quicker cabin heat.
Post #181274 4th Apr 2013 4:46pm
ebajema
Well Mick, it looks like you need to do a round Scotland trip this weekend. Maybe do the whisky tour ?? Smile, just to clean out the PDF Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #181277 4th Apr 2013 4:52pm
Either that or explain this scenario to the other half to let her know i really should have a petrol Laughing Laughing
Post #181281 4th Apr 2013 5:12pm
Googsy
Thumbs Up either that Mick or come over to Ireland have Debbie does Dallas box set Whistle Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #181291 4th Apr 2013 6:02pm
sounds like the FBH Mick, if it is not working and its cold it could still be trying to fire up and feeding fuel to the burner, which isnt igniting properly leading to the smoke.
I was getting smoke from mine before i had it changed, and masses from the new one until it burned off. Can you see exactly where its coming from? Exhaust from the fbh is under the passenger foot well. There is nothing that can't be fixed with a hammer😜😜
Post #181294 4th Apr 2013 6:06pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
FBH will work at a certain temperature regardless of whether you set timer or press remote.
Think it's below 5 or 6 degrees.
Almost certain there is a post on here that lists the conditions when the car will decide it needs to supplement the heating with no user action.
Mine does this on short journies and the smoke comes from left wheel arch.
I was worried at first but I heard the FBH running.
Maybe your FBH has decided to work again now were in 'British Summer Time'....
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #181318 4th Apr 2013 7:52pm
Well took it for a run tonight and battered its Censored in along dual carriageways and what not came home and no smoke … so far …
Typical if the FBH starts working itself now and not when its Baltic .. Rolling Eyes
@ northernmonkey .. how much did it cost to get changed Whistle
Post #181323 4th Apr 2013 8:23pm
Under warranty, but really you need to be sitting down when they give you the bill. They are the best part of £1500 to get swapped. Thud There is nothing that can't be fixed with a hammer😜😜
Post #181324 4th Apr 2013 8:26pm
With such a short commute it doesnt give the time for the engine to warm through, and the fbh will try to give a boost to the engine coolant temp, so would be running when you start it and when you turned it off, if it were working that is..... There is nothing that can't be fixed with a hammer😜😜
Post #181336 4th Apr 2013 9:22pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
Will probably be the fbh. if its def not working then the good thing is its trying to work so will more than likely just be the glowplug. i replaced one on my eberspacher, similar to webasto, and was about £30ish. not an expensive fix if you can do it yourself Thumbs Up '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #181350 4th Apr 2013 10:03pm
Paul J.
On a cold day the FBH will come on without your intervention. Not pressing the remote or not programming the timer makes no difference.
It is designed to warm the engine, and has the convenient side effect of being able to heat the cabin. Ask D3 owners!
Paul
Post #181358 4th Apr 2013 10:19pm
Googsy
Its the dpf soon Martin will promote me to head moderator Thumbs Up
Stan get down and gimme 12 Laughing Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #181371 4th Apr 2013 11:11pm
Googsy
Embarassed Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #181372 4th Apr 2013 11:13pm
Page 2 of 3 <123>
