Home > Maintenance & Mods (L322) > Has anyone managed to free a broken locking wheel nut? |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 |
Thanks.
5th Mar 2013 6:05pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
I replaced all my locking nuts a few days ago, the new key was different inside - had a black spring clip on the inside that seems designed to better fit the lugs. |
5th Mar 2013 6:10pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Don't forget to copper grease your nuts (wheel nuts that is) Present :2008 TDV8 HSE
5th Mar 2013 8:57pm |
I hope your joking? |
5th Mar 2013 9:11pm |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 |
Katash, I agree and would personally not use copper grease on threads, just a torque wrench to the correct value.
5th Mar 2013 9:27pm |
I was told to do this a few times at it makes easier removal. Has never caused any issues for me. Present :2008 TDV8 HSE
5th Mar 2013 11:43pm |
I use Shell Rhodina II for wheel nuts/bolts. It is designed for open gears in a marine environment (winches and the likes) and is therefore ideal for this use. I have a 5 kg tin sitting in my container/workshop, that will last me a lifetime as I only used the volume of a small marmalade jar in the past 15 years
6th Mar 2013 8:02am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
Always used copper grease on wheel studs and for that matter all nuts and bolts.
6th Mar 2013 9:35am |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Copper grease the outside of the nut where it meets the wheel, not the thread as this alters the torque value, stretch that stud and it's likely to fail.
6th Mar 2013 9:50am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
i personally had a nightmare with some mercedes chrome topped locknuts, the merc tool sheared off and the two front locknuts were WELL on there. (had already done the rears) i could not drill them for toffee. i bought a left handed locknut removal tool and it just stipped the nut a little and bottomed out. i eventually turned my garage upside down looking for a solution. i found my old black and decker powerfile. i snipped up an old wider flooring belt-sander belt into about 7 powerfile sized belts, and set about 'filing' the head off, i made a circular fence from some old tinplate and slipped it over the nut first to protect the wheel. after about a minute, off constant twisting you get a dishlike shape and you keep checking its grinding centrally. and just when you are nearly there you run out of belts, and snip up some more. the wheel evetually gives in and is released. and the remains simply undo with fingers etc. do people still steal wheels? maybe theres a shotage of spare housebricks down back alleyways to prop the car up? you get a nice reminder every now and then as the rusty grindings are all over your drive! |
5th Apr 2013 9:46pm |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
The guy that removed mine welded an 18 inch welding rod onto the looses cap part of the nut to get leverage to prise it off, that gave him access to the proper nut underneath which was then undone using a wheel brace.
6th Apr 2013 9:05am |
