![]() | Home > In Car Electronics (L322) > Satnav red cross |
mackempete Member Since: 17 Mar 2013 Location: Durham Posts: 60 ![]() ![]() ![]() |
Hi, thought id move this part of my first post to the ICE forum to see if it gets more attention. I've just bought my FFRR and my Satnav has a red cross through the “GPS” square in the top corner, and its displaying my position in a field in north Yorkshire. I have a 2011\2012 disk on the way to see if this improves things.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35850 ![]() ![]() |
battery disconnection [details in wiki] then maybe move to a different position ... ... - .- -.
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
I had a very similar fault on a totally different car (Audi A4). The cause turned out to be a damaged aerial lead - so it was surprising that the SatNav could see the satellites at all. I guess the timing signal wasn't good enough. Graham
Cheers gents. I'll have a go at the battery this afternoon.
belgium is the default country, you need to change it to the uk in the menu.. ... - .- -.
Finally got around to disconnecting the battery this morning (explosive charged scared me off at the weekend)
if its a touch screen then click on the uk [in the map] and click change..
ah ha cheers mate. I've been looking in navigation preferences. Assumed it would be something more system wide. |
as for the sat nav red line job, i've done a search here and the conclusion is that there is no conclusion..various answers came up like damage antenna leads to bad connections to faulty units...
Reset position to home. Still got a red cross through the GPS. Diagnostic screen still showing satalittes but not getting and position data from them... grrrr
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746 ![]() ![]() |
Think it was Dan@duckworths - pm him for a price |
Thanks Johnte. |
super8 Member Since: 11 Apr 2013 Location: Surrey Posts: 9 ![]() ![]() |
Hi.... Same issue on my 05 Supercharged... Could someone let me know how I get to the sat diag screen as I can't find any reference to it.... Tried the 1791 hack code but not letting me get anywhere... Thanks. Range Rover - Supercharged - On the drive.
