Home > Maintenance & Mods (L322) > Spring cleaning...when it finally arrives
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Decided to have a go at cleaning the interior this morning and thought I'd share a few tips.
If you have an electric toothbrush and have an old brush head it's amazing how effective this can be on the door panels, especially the tops along by the window operators. With some patience, fairy liquid or leather cleaner and a small bowl of luke warm water, a clean towel or kitchen paper the results have been amazing.
My panels are parchment and so the difference from dirty to clean is quite striking. I did the same with my Bentley a few years back and did the entire interior little by little and the end result was an interior that looked like new. When I first bought the Bentley the interior already looked pristine, but if you're one for detail and want to return the interior to the factory loom then over time amazing results can be achieved.
The trick with doing this with a tootbrush or nail brush is that its essential to keep wiping over the surface with a clean cloth and to rinse the brush in the bowl, changing the water every now and again. Especially so if you're using a cleaning solution on the leather which needs to be kept dry and should never be flooded. I used Connolly leather cleaner, 12 parts to 1 of water for this.
I toyed with the idea of swapping the existing steering wheel with a brand new one as many have done on here, but thought I'd try the leather cleaner and spent about 45 minutes on it and again the wheel now looks really fresh although it could never look like the new ones, but isn't far off.
You only have to look a the kitchen paper when you wipe the dirt away to see how much grime accumulates over the years.
I was reading a post about cleaning the headlining and depending on the types of mark on it you might get away with some duct tape which you will need to press firmly over the dirty area and remove quickly. Repeat a few times and without making the area at all bare the mark may come off and you could be pleasantly surprised.
Post #181517 6th Apr 2013 11:29am
mjdronfield
Cracking advice. Will give that a go this weekend on my ivory door cards.
Re the headlining, I've always used Vanish on a damp cloth.......perfect every time.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #181518 6th Apr 2013 11:55am
good tip, i'm of to buy an electric toothbrush and a bentley.. Thumbs Up ... - .- -.
Post #181530 6th Apr 2013 1:05pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Laughing Laughing Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #181534 6th Apr 2013 1:19pm
TugRR
. . . . I carried a small paint brush in mine for the dash area Whistle
Got that tip from James May off the telly !
Thumbs Up Where do you go after one of these . . . ?
Post #181535 6th Apr 2013 1:19pm
Rich86
Even better if you have a car attachment for your vacuum cleaner which has a small brush that will get rid of the dust and suck it away. Miele do a good one.
Post #181559 6th Apr 2013 6:40pm
I can just hear my wifes comments if I told her I was going to clean my car with a tooth brush!!! Rolling with laughter Got - 2017 SDV8 Autobiography in Loire Blue
Post #181560 6th Apr 2013 6:43pm
Rich86
Well it depends what results you want at the end of the day.
However you need to just wait tip she's at the hairdressers then she'll never know...
Post #181568 6th Apr 2013 7:59pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Well, until the evening when she cleans her teeth Rolling with laughter 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #181569 6th Apr 2013 8:05pm
Yeah, that's when she tells me she's been using mine to clean the bog! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #181570 6th Apr 2013 8:16pm
Rich86
Could be worse. She might not do any cleaning!
Post #181574 6th Apr 2013 9:06pm
