![]() | Home > In Car Electronics (L322) > Satnav red cross |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35673 ![]() ![]() |
try '753' ... - .- -.
mackempete Member Since: 17 Mar 2013 Location: Durham Posts: 60 ![]() ![]() ![]() |
Out of curiosity I checked the GPS info screen while in the under ground car park at work. Still lists satellites with their positions. Can only assume that satellite ids andtheir Geo stationary position is in the software and isn't picked up from the aerial. |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Cached positions from the last time it saw them? GPS signal won't reliably make it through a concrete underground carpark... Graham
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 ![]() ![]() |
Same happened to me. Used the 753 hack to show that there was no signal. Antenna replaced and all is good.
Where did you get your antenna from Paul? I've pm'd duckworths but not heard anything back yet. |
Had it done at the local main dealer, ISTR about £200-250 fitted, possibly less.
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 743 ![]() ![]() |
Antenna is around £50, fitting is pretty straight forward |
super8 Member Since: 11 Apr 2013 Location: Surrey Posts: 9 ![]() ![]() |
I have now resolved my SatNav GPS red cross... and here's how.
Thanks for this super8.
so its all down to a failed gps antenna, glad you two got it sorted.. |
Yip. There was no obvious damage or water ingress to my antenna. Nor could i see any obvious damage to the cable\connectors. TBH as the replacement was only 8 quid i didnt look too hard |
jackomcfc39 Member Since: 15 May 2013 Location: manchester Posts: 1 ![]() ![]() ![]() |
Did you get this sorted? as Im having the same problem richard |
