![]() | Home > In Car Electronics (L322) > CD issue |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 476 ![]() ![]() ![]() |
You need an Intravee, an Alpine KCA420i, the two leads which come with the Alpine and a 12v to 5v adapter. All available on ebay if you want to save money or from Toys in your car website if you want new items.
NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136 ![]() ![]() ![]() |
I had same symptoms a while back - check that the CD changer is not jammed. If it is jammed it will give that error message and be unable to load, but there is an easy fix that worked for me, see thread on RR.net: http://www.rangerovers.net/forum/6-range-r...med-2.html Norman Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
tap the changer with the top of a screwdriver .. ... - .- -.
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
Thanks guys, I will give it a go and let you know how i get on |
Took your advise Stan and gave it a "tap" and it worked. thanks stan, but i think i will get intravee etc |
