![]() | Home > Technical (L322) > Multiple error messages HDC inactive, SUSPENSION etc |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
Battery or alternator failing to charge. Do a search - there is lots of info here |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Have you tried turning the steering wheel all the way to the left, hold for a second, then all the way to the right? Previously..
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 ![]() ![]() |
Sounds like my problem...... It was a brake switch. Try passing the brake pedal down hard and see if it repeats it. 2011 Stornaway Grey 5.0SC Autobiography |
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 ![]() ![]() ![]() |
Thanks AA are on there way I will ask they check the battery an alternator |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
And what was the outcome? 2006 4.2 SC
Prognosis was dead alternator |
Not a 100% convinced though the non AA garage guys aid it was, the battery is obviously very low as interior lights are very dim the P light on the trans is flickering and there is not enough power to trigger the central locking. When he attached his start unit drained it really fast, and that was just enough to operate the locks. Read some things that said it could be earth leads? How can I check the alternator on the car? If I fully charge the battery will that be enough to get the car started or would I be better jump starting of the wife's Disco? |
to check the alternator on the car , connect a voltage or multimeter to the battery and run the range at idle, it should read near to 14.5 volts . ... - .- -.
The FFRR is a very complex car but as far as the battery and alternator is concerened this is standard off the shelf stuff that any competent mechanic can advise on so the AA (or their sub contractor) should be correct. Both the AA and RAC carry good testing equipment. If you're not happy, call them back.
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
i have this from time to time BUT only at the car wash - clears itself after i restart the engine.... |
So possibly the transfer box ECU (located behind the battery and below the windscreen) is getting damp?
a 'true' range rover owner .. ![]() Y. O. L. O. . |
Charged the battery tonight, got 12v across terminals started car and it dipped to 11v so defo looks like altenator, how far would I get on battery only with no alternator? Thinking of getting it to IAWA in Wellingborough any body used them are they good? |
