![]() | Home > General > Good buy? |
| Robbieowens Member Since: 19 Mar 2013 Location: Wirral Posts: 64
Hi,
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
The heavy steering may well be that your issue lies with either the servotronic valve or the BCU both common failures.
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
Good buy, or good bye? |
The warranty company will not pay for pre existing faults.
Fair point, looking online those faults don't seem too expensive to fix however as you say there are plenty of good cars out there. I'll wait till its fixed and then see how it is. |
| bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055
Presumably you want honest opinions, and if I'm totally honest it sounds overpriced.
Thanks bozmandb9, I do want honest opinions. The deposit was £200 and its written and signed on the agreement what needs to be fixed, however I first put the steering down to tyre size so I may need to revisit that, the dealer suggested a £500 deposit but didnt argue when i said £200, as for being overpriced I honestly thought it was reasonable based on what I've seen on eBay and autotrader....what would your valuation be? |
| Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509
Robbie you dont seem happy with the asking price even if the faults are fixed and i dont think I would be either.
| steptoe Member Since: 23 Jul 2012 Location: london Posts: 382
I had the Sat nav and indicator problem ( work but no noise or indicator light on the dash), it was the LCM (light control monitor). An expensive part, and it needs to be coded to the vehicle. |
If I was buying right now, I'd be buying a 2007 Facelift 4.4 Vogue SE petrol for just under £12k, with 106k miles.
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
I've had both issues and both simple fix's. my head unit was goosed when I went to pic mine up. Could get radio but no display on the screen, indicators worked but couldn't hear them etc. eventually an Expedia cemindy pulled fuse 40something for a few mins and it was fixed. The steering I thought was normal until I used my RAC and reset everything for the first time, nearly pulled the steering wheel off it had gone so light. So your issues could be simple sizes or be power steering pump or ECU related causing costing ££££ [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Or how about this one? http://www.autotrader.co.uk/classified/adv...?logcode=p
Thanks, the one in Leeds looks good might be worth a phone call. |
| Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746
Think it's only an SE, so would be cheaper than Vogue.
| All times are GMT |
