![]() | Home > General > Aircon question for RR 2010 |
Your car doesn't have air con. It has climate control, it's designed to be left on all the time. You should leave it on and then set the temperature you desire. The A/C is used to dehumidify the air, which stops your electronic components malfunctioning as the copper microswitches turn green with the ambient moisture, your headlining sagging and various trim pieces going mouldy.
Set the temp and LEAVE it on at all times. The A/C light will always be on as per Dan's post this does NOT mean the system is cooling. |
Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420 ![]() ![]() ![]() |
Thank you guys, I only started using the climate control a couple of days ago...now it makes sense |
