![]() | Home > Maintenance & Mods (L322) > Installing a MP3 Changer/itouch/dvd & Intravee II in 54 |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
Just wondering if that set-up would double up as a hands free phone kit if you were using an iPhone? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
yes but depending on you version of generation of iPhone,it would talk via the car standard blue tooth and override the mp3 output as normal, you would need a charge adapter wired in after a gen 1 iphone as they change from 12 volt to 5 volt there on,
Liszt Member Since: 22 Apr 2010 Location: Northants, Uk Posts: 15 ![]() ![]() |
So, last night I looked at my 10 pin plug and my 3/6 pin sockets and did a bit of delving. Looking at the wire colours and the circuit diagram I came up with the following table for moving the pins. Moving the pins was easy enough. Lift up the little flap holding them in place, press down on the pin and gently pull.
Duke Thrust Member Since: 07 Jun 2010 Location: Gloucestershire Posts: 59 ![]() ![]() ![]() |
Chaps,
you need the alpine KCA-420i unit which lets you do everything in the menu on the dash via the Intravee II,
Thanks.
Hi Intravee II cannot support a USB drive currently, I have just got a beta firmware which folds my mirror when I take the key out and opens them when the key is put back in!, heaps of other extras coming soon too, so can only recommend it.
