![]() | Home > General > Rusty Rangie |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
They all do that sir. Part of the service. Graham
You could try complaining. I did, and got nowhere. What a load of crap. Corrosion on a nearly new modern car. Graham
rjbax1978 Member Since: 07 Oct 2012 Location: northampton Posts: 16 ![]() ![]() |
I had the same problem with the rear window surround and they are going to replace under warranty 2011 TDV8 Galway Green Vogue Se
barrieeld Member Since: 07 Dec 2010 Location: Scotland Posts: 260 ![]() |
I had this on my car and although the dealer tried I got no place as my car was over 3 yrs old.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
the rubber trim strips at the bottm of the window are a relatively cheap fix,most i've seen are the same. |
The rubber window trims are aluminium inside - its not rust but some form or alloy corrosion. Very common on older cars so just buy new ones. |
Sounds like galvanic corrosion where two dissimilar metals (of which one is less noble) start to react basically create a battery when an electrolyte is added (water, preferably slightly salty). The less noble metal will then start to corrode as it loses electrons.
Brewster Member Since: 11 Sep 2012 Location: East Yorkshire Posts: 26 ![]() ![]() ![]() |
When I bought mine I noticed a couple of rust bubbles under the paint. I thought they had a 6 years corrosion warranty so went to my local dealer who took some pictures. Came back with the response that because there wasn't a hole in it it was a non starter. I pointed out that in the warranty book it didn't state this and it repeatedly mentions corrosion warranty not perforation warranty ie if it has corrosion before the expiry of the warranty it was covered...apparently NOT!!
