![]() | Home > Wheels & Tyres > TPMS |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
I have just acquired a new set of wheels and it looks like they are fitted with TPMS.
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Post 2006 vehicles will recognise new TPMS sensors, but you need to go for a 15mile drive. Not sure about pre 2006. This does assume that the batteries in the TMPS sensores have not gone flat. I think ther may have been a change of sensor around 2010 and I don't think they are compantible with 2006 to 2010 system. I think the 2002 TPMS system uses different sensors to the 2006 onwards. 56 TDV8 Vogue SE
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
Put your spare on as a road wheel first, it will/should self-learn all new sensors fitted to an axle on the 2006-2009 system, mine did. Then put your spare back in the boot and put your 'permanent' road wheel back on. |
Fitted all five wheels yesterday and went for a run but nothing happened.
Nothing appeared on the dash at any time so I reckon the car has not detected the wheels.
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
Ian, just to clarify, is the TPMS warning light illuminated on the dash? 2007 TDV8 Vogue SE Java Black |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
Is TPMS a nuisance on an already complicated car ?
If your buying brand new next time, you'll probably find it is.
No warnings on the dash and no menu option to change the pressure setting.
It looks like you have the TPMS disabled. You would have a low pressure warning light if it was enabled and the sensors weren't recognised 2007 TDV8 Vogue SE Java Black |
