Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 22 of 49 <123 ... 212223 ... 474849>
the IIDTool has the ability to adjust the volume of the parking sensors so there's a possibility that it could re-activated your beep.. ... - .- -.
Post #183746 20th Apr 2013 9:34am
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Tool will not allow configuration of the BMW ECU .... Probably due to slightly different firmware.
Post #183758 20th Apr 2013 10:28am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Hot and Cold monitoring
So, I have made sure I have the latest firmware 2.17 as of today, but I do not know how to access the hot and cold monitoring of the light control module. It does not seem to appear when going through the list on the car. What is the correct pathway to it, and is it available on the 2002-2005 version? Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #183778 20th Apr 2013 2:14pm
cold and hot monitoring should be in the 'lcm' menu.. ... - .- -.
Post #183781 20th Apr 2013 2:48pm
MikeG
Netherlands 2007 Range Rover Vogue TDV8 Santorini Black
Steve, just checking before I order one... I have a model 2006 TD6 (Vin starts with A6......) but it was delivered in August 2005. If I have understood all posts on here and the information on your site correctly then I should be ordering the IID for the 2006 - 2009 model, despite the FFRR being delivered in 2005, correct?
New to this and a whole new world is opening up for me so excuse me for maybe asking dumb questions!! Embarassed
Thx for your help!!! Mike.
2007 Range Rover Vogue TDV8, Black, Sand Leather Seats & Sand / Black Interior.
IID Tool from GAP Diagnostics.
Post #183789 20th Apr 2013 4:43pm
ebajema
Mike, if you post a photo of your screen in the car. That is one of the best indicators. The touchscreen version has fewer and different buttons on the MY2006 and up.
Mine is a MY 2006 but built in May 2005 and has touchscreen/MOST system etc.
I use the Faultmate and not the IID by the way. MY 2010 5.0 SC Galway green and sand interior!!
Post #183796 20th Apr 2013 5:39pm
davidmg
2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I have a similar vehicle registered 05 but 6A chassis so ordered the 2006-2009 and it works fine
Post #183800 20th Apr 2013 5:49pm
MikeG
It's a touchscreen so must be the 2006 then... See picture.
I checked out the faultmate but read some PDF document where it seemed most of the software fitment qualification is till 2005 or even mid 2004 so this confused me to if/how it would be suitable for my vehicle or will have more or less options then the IID.
Thx for your help, input and experience sharing for your faultmate!! Mike.
Post #183801 20th Apr 2013 5:51pm
MikeG
Thx David!! Thumbs Up Mike.
Post #183803 20th Apr 2013 5:53pm
Mike, vins that start with a6 require the 2006 onwards IIDTools... ... - .- -.
Post #183813 20th Apr 2013 7:40pm
MikeG
Great, thx Stan for confirming I require the 2006 onwards... I like the fact the IID is small and can be stored in the dash so at hand when needed. Appreciate the help!! Thumbs Up Mike.
Post #183830 20th Apr 2013 8:28pm
Flashman
Tried looking in the LCM menu and there is nothing there, lots of options for follow me home etc but not a single CM or HM. Maybe it is not available on the 2002-2005 model. Tom
Current Drive
Previous Drives
Post #183937 21st Apr 2013 7:04pm
there's a drop down select menu on the GAP site and these functions are there...no doubt Steve will be on soon to help. ... - .- -.
Post #183939 21st Apr 2013 7:17pm
Flashman
I contacted Patrick and he told me to uninstall the old updater and install the new one you will have to contact them directly if you need it although you should be able to get it from their site.
Then I updated the firmware and it works perfectly giving me access to all the hot and cold monitoring options. My version before the upgrade was 2.17.01 but the latest is 2.17.03 with 04 due out soon. Hot and cold monitoring was only activated on version 2.17.02 onwards. So check your version.
Patrick did say that for some users holding down the + button for 3 seconds can get the menu working if it sticks, but with the new update the menus work faster than before.
Great customer support from GAP-Diagnostic again! Tom
Current Drive
Previous Drives
Post #184236 23rd Apr 2013 3:18pm
daveo
big thumbs up for the gap team Thumbs Up Thumbs Up Thumbs Up they wrote me a patch that allowed me to programe the rain sensor and now it works, never did since i had the car but these guys dug deep into the BCM and pulled the right codes out..thanks again Thumbs Up
now where would you get service like that Smile V8 facelift Range Rover Autobiography 22" wheels.
Post #184374 24th Apr 2013 12:24am
