![]() | Home > Off Topic - Other Cars > M Class OR x5??? |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
Both good cars,
DaWalley Member Since: 24 Jan 2013 Location: Cheshire Posts: 42 ![]() ![]() ![]() |
Cheers for the info!! |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Well, I tried both extensively about 18 months ago. Personally, I'd take the BMW over the ML, but you need to try them both; neither are anything much like the FF to drive. I found the X5 to be quite car-like, the ML was less so, but neither felt as big (or luxurious) as an FF or indeed the D3.
Oh yes. I forgot the bloody run flats. Nightmare. |
Yet again, thanks! I have heard a lot about the run flats being annoying / costly, but most other points seem to be favouring the X5 really.
Yes, I had them on a 330D - noisy, hard ride, poor grip esp in the wet, wore out quickly, bloody expensive, no choice, and unrepairable. A sidewall tear meant I was stranded and the "run flat" feature didn't work. Had to be recovered (luckily I had a spare car at the time) and a week to get a new tyre.
Dont forget the X5 suffers badly with worn rear bushes that cause the wheels to toe-in at the rear and shred the inside of the tyres |
Thanks. I'll make sure to check on it for these too. RR Vogue TDV8 08 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7933 ![]() ![]() ![]() |
X5 every time. But then I'm more of a "BMW Man".
Has she driven the RR?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Get a Honda cr-v.... If you are not going FFRR then you might as well go sensible and bullet proof reliability. Previously..
campaj1 Member Since: 22 Oct 2012 Location: Cheshire Posts: 729 ![]() ![]() |
go for a current generation X5 if you can stretch to it: the handling belies its size! |
