![]() | Home > Technical (L322) > Weird noises from below dash |
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222
Hi All, Looking for a bit of help to get to the bottom of a weird noise that has just arrived. When I unlock the car and open the door, I can hear a loud clacking/ clicking from behind the dash. It lasts for about ten seconds then stops- it's loud and noticeable. I know ten secs doesnt sound long, but it's a noise you cant ignore. I have searched on here - some mention the heater flaps/solenoids are moving ready for starting the car etc, and if it is this, it's likely something is bust or failing to engage somewhere. I have never heard the noises before. Any ideas? Thanks in advance.... |
| Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267
Steering lock?
I kow the noise you mean, its not that though. This sounds like a midget under the dash, poking a plastic fork into the blades of the heater fan.On and off for ten seconds. Maybe thats what it is. |
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2723
Still got the noise -am sure now it aint a fork-wielding midget- had the centre vent out and waggled the cable connected to the thumbwheel... And it was worse, so I am pretty sure it's the lower business end of the cable that is clicking/clacking. Can anybody tell me whereabouts this green Bowden cable connects to the heater box? It looks, how shall I put this, intense, behind there....thanks in advance. |
Got to the bottom of this noise - it's the heater flap stepper motor that controls the 'door' for the footwell outlets. It works ok - or at least I think it does, moves the flaps when the heater controls are operated. For some reason, it has a clacking fit when the car wakes up. It also clacks once every 45 seconds - as the ATC ECU checks it's position.
Maybe useful for some one in future: the stepper motor can be accessed for replacement by removing the centre vent (with thumbwheel) and the lower switch panels. These pull out -carefully- after you have removed both of the console side trims. These are held on by a single screw at the rear under the dash, and simply pull off along the curved finisher.
| paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502
Cheers paneldamage! Your a star!!
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
I have this on mine but sound is more like someone with leather trousers going slowly down a slide if that makes sense.. It's happens for about 5 secs after opening door. Present :2008 TDV8 HSE
This one? EBay item no eBay Item No. 350847743462 |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
interesting. It was a very common issue with P38s. I had to change one or more of the stepper motors on pervious P38s and it was a complete pain. Major dash out job to get to one of them..!
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
Would this stepper motor be affected by low outside temperature? Ours has just started doing this recently, when the cold weather hit, so the heater controls are both on high temp and top and bottom vents are open.
| All times are GMT |
