Home > Technical (L322) > Doors wont opne with remote or key
kiter
went out tonight to try and put my new floor mats in the RR and I cant get the doors to open at all - neither remotes work and the key in the lock does nothing either............ what have i done!!!! car been starting fine - used it on Sunday and started no bother - wasnt a long run admittedly. Any thoughts?
Post #184493 24th Apr 2013 5:55pm
Flat battery …
Post #184498 24th Apr 2013 6:00pm
kiter
just been doing a bit more googling and seems like it - suggestion about getting power to starter motor from underneath the car (its sitting a normal height and I'm a skinny wee runt - so might be able to reach it). Any thoughts?
Post #184501 24th Apr 2013 6:10pm
..or power through a tow socket ,if you have one. ... - .- -.
Post #184505 24th Apr 2013 6:30pm
kiter
mmh - that was my other job tonight as the towing ecu arrived today as well so in future would be an option but not tonight I'm afraid............ flamin typical, came home early to get all these jobs done. Other suggestion on line is the side indicator - got that out without any issue.
Post #184507 24th Apr 2013 6:36pm
kiter
Success with using the new battery, connected to a bit of pared back live wire on the side indicator - left it 2 mins and hey presto doors unlocked with the remote no problem. Razz Not that clever usually so feel like I deserve a wee dram tonight......... Will get the new battery on tomorrow - not going to push my luck tonight! Anyhting I need to be aware of when connecting up the new one? (apart from the left to right full lock once its going).
Post #184767 25th Apr 2013 9:08pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Without staying the obvious, just make sure the new battery is a) quality and b) man enough for the job. The electrics on the FFRR are ultra sensitive to strong voltages.
You also need to look at your drivers door lock to ensure you're not caught out again. Thumbs Up 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #184769 25th Apr 2013 9:14pm
kiter
yep - got a contact in local motor factors so he kept me right - still lightened the wallet by £120.00........
Post #184771 25th Apr 2013 9:21pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Also need to find out if there is a fault which drained the battery, or your new one will just go flat and be ruined....
Search final stage resistor on here as a starter for ten.... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #184783 25th Apr 2013 9:56pm
kiter
ok - new battery on and everything appears fine - did the left to right full lock and no errror messages and car starts fine - just left it for 20 mins and red led at P is out, safe to assume it is sound asleep? Really appreciate all the help and advice on here Thumbs Up No doubt wont be long before I'm back with something else........ its worth it though, as I do really like my FF
Post #184960 26th Apr 2013 6:19pm
sounds like a result.. Thumbs Up ... - .- -.
Post #184971 26th Apr 2013 7:08pm
Post #184976 26th Apr 2013 7:46pm
kiter
hope so - thats the parking sensors front and rear working as well, 2 faulty sensors and a broken wire. Just tow bar electrics, mud flaps and digi Tv upgrade to tackle now, latter might need to wait a bit longer
Post #184985 26th Apr 2013 8:22pm
