Home > Technical (L322) > Front passenger door electrics???
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Hi guys.
I've just disconnected the battery (following procedure) and since re connecting all the front passenger door systems don't work? Ie: mirrors, windows locks. Tried from drivers controls /key aswell and no joy?
Are all these systems on one fuse? If so which and where!
Any suggestions welcomed!
Thanks
Post #184474 24th Apr 2013 4:42pm
TimP
England 2005 Range Rover Vogue Td6 Java Black
Have a look at fuse # 24 in front (glove box) fuses.
Post #184560 24th Apr 2013 10:17pm
SATVC
Thanks for the reply! I've checked fuse 24 and it looks fine?
Post #184562 24th Apr 2013 10:19pm
Have you tried the steering wheel lock to lock to see if it will reset the ECU's
Post #184565 24th Apr 2013 10:32pm
SATVC
Yes, it came up with air susp inactive so the compulsory left to right happened to clear that?
This has got me boggled! Door speakers work fine but everything else electric is dead? Weird it being only the one door?
Post #184567 24th Apr 2013 10:34pm
SATVC
Looks like a failing door control module!!
Post #184847 26th Apr 2013 9:12am
