![]() | Home > Maintenance & Mods (L322) > My Air Con doesn't work |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
I have gas , the clutch engages cleanly and the condenser seams un-damaged but,,,,,,,nothing gets cold.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Do you have fans/blowers? (thinking FSR first)
Thanks for the replies so far , to me it does feel like there is no condensing going on but I have had it re gassed twice so Im thinking blocked or pinched plumbing but where and how ? 2008 MY Supercharged
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
the air condenser is right at the front and is easily hit by stones and debris of the road...you could have a hole somewhere resulting in leakage.. ... - .- -.
Thought of that as well but it's holding pressure . There just seems to be no clear reason for the total lack of cooling despite everything seeming to work . 2008 MY Supercharged
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Have you cleaned the TEMP SENSOR ? They get dirty and stop sensing its hot (Don't ask me how though) |
But if you press the max button you bypass the tem sensor and put the system in to full steam ahead but as i said , zilch |
mmmm |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
When you re-gass it this time, let them add that fluorescent stuff. That way you can find out where the leak is. Also last times when regassing, was there any liquid left or didn't they check/tell you ? MY 2010 5.0 SC Galway green and sand interior!!
afaik air con gas already has some kind of fluorescent stuff in it and all you need is a UV lamp to see any leaks.. ... - .- -.
I have only seen it once as it was being added to the AC of my GMC. Very sure here they don't have it in. MY 2010 5.0 SC Galway green and sand interior!!
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
I think you need the car put on diagnostics, preferably Testbook, otherwise you could end up chasing round for weeks and get no |
Such a simple problem in the end , this really only applies to cars like mine with four zone climate and to be honest I have never heard of another but this means I have my entire centre console full of a second HEVAC unit and when it was re-gased all the gas was drained out the system but when replaced only the front system took the gas . So when I turned on the rear system gas rushed in , the pressure drops , bothe systems stop working due to lack of pressure . Moral of the story keep my rear system on when re- gassing . 2008 MY Supercharged
| All times are GMT |
