![]() | Home > General > 1 week anniversary - broke down already :( |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
sounds like the battery ...if it starts after the jump make sure you set the steering parameters.. ... - .- -.
Robbieowens Member Since: 19 Mar 2013 Location: Wirral Posts: 64 ![]() ![]() ![]() |
Thanks Stan, not the start I wanted to owning a FFRR but never mind, hopefully just the battery and Rac will sort it. How do you set the steering parameters? |
after the range has started turn the steering wheel fully left and then fully right , this avoids getting error messages on the dash..info is in the wiki under 'battery disconnection' ... - .- -.
Thanks Stan, still waiting for RAC. Is this a common fault I.e. what appears to be a good battery dying overnight? Nothing was left on in the car. |
the fullfat is very heavy on the electronics and any battery around 3 years old might need changing..some have had the same battery for longer without any problems but generally its 3 'ish years..
Disaster averted |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
you'll find anything left on overnight in a FF will drain the battery lol. These things will happen |
Or take the bulbs out |
Or fit LED ones like a lot seem to do and they will drain less power and stick a 110ah battery in the front and a spare in the boot |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
My Dad had tons of problems with his (non-Land Rover) mini-van. All the electronics were very good at keeping the engine sounding and starting well as the battery got worse and worst. It did cause just about every electric gizmo to malfunction though. Finally, the electronics reached their limit and the battery 'suddenly failed'.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
