![]() | Home > Maintenance & Mods (L322) > [SOLVED] Front Brake Disc Retaining Nut Seized !! |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Damn, it has only been in there @ 18months and I copper-eased it on the way in. (Perhpas it explains why they were not fitted to the car when I bought it, but I didn't like the idea of the discs simply "floating", even though held in place by the pads and wheelnuts/wheel.
A small pin type chisel to get it moving |
| PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877
Blow torch to crack it. |
Don't have super heat e.g. blow torch, so will report back on small chisel approach |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Big drill bit to get head off.
| jerrytlr Member Since: 02 Apr 2013 Location: France Posts: 66
When I had the same problem with my P38, I drilled the head off, and then once the disc was removed, the bit left behind was easy to remove with mole grips.
A few taps with a suitably sized cold chisel got it moving |
It will probably wash off after a few washes though Joe as the water will run past it when the alloys are on |
| All times are GMT |
