The 5L40 is not that bad. You have to know its shortcomings. That said, as I want to keep my TD6, building a tougher box is on my long list as well.
RS, sounds like you've done nearly everything to stave off a failure in the short term. It is a bit late now but one thing I would have done is a valve body upgrade. This is from another thread I posted to a while back:
I did considerable research on this transmission and spoke to all sorts of people from Ian Ashcroft, to John Mackey, to some very competent folks at Sonnax Transmissions.
The 5l40E has some very real problems - nearly all of which are pressure related. In a nutshell, the biggest wear issues stem from wear in the valve body bores and in the torque converter clutch valve bore. It seems that, for whatever reason, the aluminum used by GM in the casting of these pieces is softer than the material used in other (older) GM transmissions. This wear leads to improper shift/lock-up pressures which in turn leads to premature wear in the rest of the transmission components (which drop particulates into the fluid and exacerbate the wear in the valve bores) and, at some point, transmission failure.
All of the people I spoke to concurred on a number of items:
-'sealed for life' is not a good thing.As the filter is on the suction side of the system, it can't be made too fine as otherwise it would cause cavitation in the pump. These means that wear causing particulates, once in the transmission fluid, are there to cause damage till removed - or transmission failure. Early, regular fluid changes are good and necessary.
- using the proper transmission fluid is vital. The valves tend to oscillate relatively rapidly in their bores and the GM engineers put considerable effort into the interaction of the materials vs. pressures vs. wear problems. Use only the recommended fluid - not all fluid is alike.
- when transmissions are rebuilt, cleanliness is vital as is checking the tolerances in the valves and the pump
- after a rebuild, changing the fluid is almost more necessary than before to reduce the likelihood of a repeat failure
There used to be a more complete article on pressure loss in the 5L40 due to valve body wear on the Sonnax website but it has since been removed. Nevertheless these articles are good for info as well.
http://www.sonnax.com/publications/transmi...rse-or-tcc
http://www.sonnax.com/system/pdfs/177/orig...09-RCW.pdf
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
