![]() | Home > Wheels & Tyres > TPMS Warnings |
it can be turned off if you have diagnostics which can edit the CCF file, for example the IID tool or a Faultmate. Do a search on here for TPMS and you'll see a load of similar issues. I turned mine off for similar reasons, i.e. being unreliable. |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
I get this and so do some other members. It's an age thing; batteries in sensors fail after 6 or 7 years, so new sensors needed 2007 TDV8 Vogue SE Java Black |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Whilst my TPMS has no issues at the moment, I purchased a set of new sensors from eBay for about £30
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
..and, the corrosion on the valve stems... ... - .- -. Y. O. L. O. . |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Thanks all! I'll get it fixed when I have it in for servicing, but my excellent indie mechanic is NOT close by, so I don't just 'drop in.'
ID3 tags? ID2 tool? |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I also get this occasionally. Maybe once every 30 minutes.
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
It is common, but it is a fault!
Thanks. |
I've been running my SC for three years the TMPS warning only comes on when one of the tires is too low on pressure. Haven't had any false alerts, so it sounds like you have battery issues. MY 2010 5.0 SC Galway green and sand interior!!
