Home > Maintenance & Mods (L322) > Battery again
supershuttle
Battery again
Car wouldn't start at lunchtime, good job SWMBO was home so I could take her car to the pub whilst the RR was on charge.
However on a serious note, this is getting to be a regular occurrence - I know that the FSR is always pointed to as the culprit but is there any way of checking or should I just change it anyway Question Geoff
Post #186178 2nd May 2013 2:29pm
In the first instance I would be inclined to fully charge the battery, disconnect the earth terminal from the battery overnight and check the voltage on the battery next day.
At least then you have eliminated / found a battery fault.
Then the fun begins. Very Happy
Post #186186 2nd May 2013 3:53pm
if you have 3hrs to spare Geoff there's an interesting thread here re battery draining problem..
http://www.fullfatrr.com/forum/topic15891.html ... - .- -.
Post #186191 2nd May 2013 4:05pm
Saltyfish
England 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Make sure your sat nav is shutting down, ive unplugged mine and my battery drain issue has been resolved. 04 Vogue 4.4LPG.
01 Vogue 4.6.
00 Vogue 4.6LPG.
99 Discovery ES 4.0LPG
96 Discovery ES 3.9LPG.
Post #186430 3rd May 2013 7:22pm
