![]() | Home > Maintenance & Mods (L322) > New engine needed |
Very sorry to hear that ! There are a few other members on here that have engine issues with that particular engine. They are looking for replacement as well, although I tried to make a case for refurb, depending on the cost of course.
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Are breakers yards an option? |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
Rugby, did you do a compression test without putting oil in the cylinders too for comparison? was it using water, oil, engine making odd noises when it was running? '04 td6 se
Could it be valve related ?? The valve stem seals ?? MY 2010 5.0 SC Galway green and sand interior!!
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
4.4 L322 ? Diesel ? or Petrol ? Far to many gone... |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
surely it would be near impossinle to build an engine from the top down only?. think you have to be able to split it to get the crank in. if thats the case you could do the pistons from there. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
little car say 2003 , so its a petrol. ![]() Y. O. L. O. . |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I'd go with crookedm - see what you can find at a breakers. I think it's quite likely that there would be BMWs with fine engines but other issues and not economically worth fixing. Good luck. |
Also worth checking the camshaft timing. i think these engines can have probs with the timing chains or tensioners or something. '04 td6 se
Stroker Member Since: 03 Jul 2012 Location: Switzerland Posts: 3 ![]() ![]() ![]() |
smoke and oil burning can be a result from a bad crankcase ventilation. blocked pvc valve or worn diaphragm in the back of the engine. normally the m62 is a very solid engine. check this parts. |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
I saw you've had a compression test, but have you had a leakdown test? This will tell you which side of the engine is worn - if the compression loss is past the rings/cylinder wall, or whether it is on the inlet or exhaust valve(s).
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
@rugbyxv have you been to town and country in cubbington to see what they say??
RugbyXV Member Since: 14 Feb 2013 Location: Rugby Posts: 42 ![]() ![]() ![]() |
T&C say a new engine resulting from bore wash as do a couple of others too. Glazed walls i would guess, so I have decided to drop another engine in and am looking for one now. I'm going down the LR straight swap route rather than a BMW. Will I need to change the ECU or will mine be ok as I assume the electronics will just slot in too?
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
Have you tried . . .
