![]() | Home > Technical (L322) > had her 2 days and already battery problems |
I seem to remember that around your model year there were a number of issues with the batteries and some cars had updates to one of the ECUs (as well as a new battery) in a recall.
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
"battery management system" (or something like that) has been reset and that a reset is a worksop thing"
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Have you spoken to the last owner and asked whether he had this problem?
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
yeah - whenever the "low battery ....start engine" comes on the engine starts absolutely fine. But clearly the battery has lost its edge as you can't run any ancillaries for more than a few minutes before the message comes on so thats means it's pointless using things like park heating / venting (something I specifically wanted) as it has no chance given that they swallow so much of the battery charge. CD player / sat nav / blowers etc all cut out until engine is started.
IWC1 Member Since: 11 Jan 2013 Location: suffolk Posts: 18 ![]() ![]() ![]() |
To start with I recommend that you take a good look at the battery.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 839 ![]() ![]() |
sounds to me that you should check....you have the AGM battery
The battery on the car is branded as a Varta (has a small Landrover Jaguar sticker on it). Dealer tells me that is a standard fit. Been on the car since new apparently.
depending on when your MY11 rolled off the production line, it will have a standard battery or AGM type.
Sorry for being thick, so is it generally regarded to be better to have an old fashioned battery type or an AGM ?
The advantage of the AGM is that it is quicker to charge, and therefore more suitable for the battery management system that LR designed for the MY11 onwards, and also that it should be able to start the engine when only partially charged.
well....dealer fitted a brand new battery. (AGM type)
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 ![]() ![]() ![]() |
It's a bit vague as really it was the 10MY facelift models with the 3.6 which had most attention.
the early 4.4s had the problem
There was a a ECU flash and a battery regulator module
