![]() | Home > Technical (L322) > Whining noise from front end TDV8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35816 ![]() ![]() |
before you go any further i would swop the wheels/tyres, it 'might' be the cause and obviously the cheaper solution... ... - .- -.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
An All Terrain pattern tyre will naturally produce more road noise than the standard road patterns, and this will change with road surface.
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263 ![]() ![]() ![]() |
I might do this today...if it stops bloody raining!
Right changed the wheels today....incredible, noise seems to have stopped.
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi can you confirm it was just them tyres then if you drove it more since last reporting.
Sorry very disco, have not had a chance to take her out, plus not really wanting to use her with dodgy wheel bearing.
Ok, thanks
Very disco
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
I have the grabber at's on one of our hilux, have the same noise from the front end, thought it was the wheel bearing, gave it a good going over and swapped the wheels over from the other hilux which has bridgestone duellers on. Noise disappeared. There is nothing that can't be fixed with a hammer😜😜
