![]() | Home > Maintenance & Mods (L322) > Bonnet access mode |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
If you look at the bonnet hinges, there is a clip on each side with a bent out tab. These tabs lock the bonnet into the first opening position. If you bend the tabs out, the bonnet can rise to the near-vertical access mode.
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
There are photos of the fixings in this Wiki: http://www.fullfatrr.com/forum/topic16155.html |
And you need to pop out the two hydraulic struts ! .
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
easily done on your own , unless you are short! |
Brewster Member Since: 11 Sep 2012 Location: East Yorkshire Posts: 26 ![]() ![]() ![]() |
I use a short piece of cord to tie up one of the struts for when you're lowering the bonnet back down, it saves it digging in if you're doing it on your own i.e. you can't be at both sides at once ..just a thought! ...Always time for a brew !!
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Thanks guys 2009 Vogue TDV8 Nara Bronze
