Home > Maintenance & Mods (L322) > Air Con blowing cold from one vent only
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Hi all,
Is there a separate temperature sensor in each of the dash vents? My AC is blowing ice cold from the passenger side dash vent but only coolish from the drivers side.
Vent Dial is turned to maximum cold setting too so not sure why the discrepancy.
Any thoughts?
Cheers
C African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #187106 7th May 2013 8:11pm
daveo
i have this too, one vent blows warmer air then the other, but i know there is only one temp sensor located in the heater control unit. V8 facelift Range Rover Autobiography 22" wheels.
Post #187142 7th May 2013 10:41pm
I quote from Workshop Manual,
"If a fault develops in the input from the temperature selector switch on the control panel, the ATC ECU adopts a default
value of 24 °C (75 °F)."
This would tend to explain why one side vents blow warm ie 24C and the other side vents operate correctly in response to the setting of the appropriate lh / rh temperature selector switch.
I think the only way to resolve this would be to connect to diagnostics and find / clear / resolve the logged fault.
Post #187163 8th May 2013 8:51am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Hmmm - I now seem to have these symptoms! The passenger side blows chilled air, but the drivers side is non chilled. However, if you turn up the temperature on the drivers side then it is happy to heat up. Could there be a flap stuck somewhere? My IID tool shows no HVAC errors however (which I would expect if one of the temperature switches was giving errors)...
Post #270442 12th Jul 2014 6:36pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
I've also had these symptoms when:
a) the air con gas had leaked to a low level
b) the compressor was fubarred
perhaps get an el cheapo air con gas top off first to see if that helps?
Post #270450 12th Jul 2014 7:34pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I can confirm I've had this twice and it was fixed with a recharge - seems I have a very small undetectable leak.
to check this (if you have an IIDTool) check live values for your evaporator temp - you'll find its not very cold when running.
Post #270451 12th Jul 2014 8:30pm
Richard
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
I have exactly the same issue, had Kwik fit do a recharge and after that all the vents were cold for a week. So it must be a gas leak.
Post #270459 12th Jul 2014 9:46pm
VaguelyVogue
Thanks guys - off for a recharge (it's a few years since the last one)!
Post #270558 13th Jul 2014 11:00am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Done a search and this thread seems to say a regas may cure cold from one side only.
I have the same symptom now with ice cold on any passenger vents and only ambient on any drivers vents.
Does anyone know if the blend motor throws up a DTC
I have no DTC's and therefore wonder if the blend motors is actually at fault.
Cheers Thumbs Up [/u] 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #482277 30th Jun 2018 5:51pm
