![]() | Home > Maintenance & Mods (L322) > Gearbox oil change or not |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
I did mine at about 88k.
How long are you keeping the car though? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
robjp Member Since: 14 Jan 2013 Location: North Wales Posts: 104 ![]() ![]() ![]() |
It's a difficult call.
CHANGE !!!!!!!!!!!!!!!!!!!!!!!!! The GM gearbox NEEDS regular ATF changes. Just follow the normal service interval with the OEM filter (not cheap aftermarket ones).
Elena Member Since: 10 May 2012 Location: Coventry Posts: 42 ![]() ![]() ![]() |
Hi Kingpleb
Just checked the workshop manual and it says filled for life. I still maintain, especially since the GM gearboxes have a tendency to eat themselves, to replace the oil and filter.
I replaced the ATF and filter of my ZF box and the small niggles went away. That was at 50,000 mls and 6 years. Be glad that your box is fine (many of the TD6 GM boxes don't last that long by the sounds of it) so I'd treat it to some fresh ATF and a new filter |
roger 47 Member Since: 24 Aug 2012 Location: Exmoor Somerset Posts: 80 ![]() ![]() ![]() |
I've just changed my gearbox oil a few weeks ago at 50,000mls. Just the oil this time not the filter, I'll change the filter and oil again in July. I had no problems with the box at all very smooth gear changes. I got the impression after the oil change that it was even smoother but that might be my imagination. The colour of the old oil was very slightly dark when it was in the drain container but if you dipped your finger in the oil it came out clean no bits came out with the oil either. The drain plug was clean also. I'm glad I change the oil as now I can, hopefully, see what condition the gearbox is in. '88 RR Classic, '90 Classic, '93 Classic, '02 Discovery TD5, '55 Discovery 3, '01 P38 4.6, '06 L322 Vogue TD6, 2012 L322 Vogue TDV8, 2017 L405 Autobiography
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
To be honest, I am surprised you even question it.
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
I have to agree with the above. There is no way you wouldn't change the oil in your engine.
Thanks guys, I have printed the instructions on changing the oil and I will take it to my my mechanic just to show him how straight forward it is., anything I should look out for that may indicate a problem. Also which oil is recommended. |
In the Wiki are the oil recommendations.
