![]() | Home > Technical (L322) > U0122 and several other faults... |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
More specific as to the faults indicated please? .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
found this re the u0122 code, hope it helps,
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
Funnily enough i experienced the exact fault the other day, a batt disconnect sorted it out for me.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Lost comms with steering sensor..... Turning the steering wheel all the way left then all the way to the right, does that clear that fault? Previously..
MikeG Member Since: 14 Apr 2013 Location: Netherlands Posts: 182 ![]() ![]() ![]() |
Barracuda, I had seen your post and there for tried the disconnecting of the battery but in my case that didn't help...
davidmg Member Since: 29 Mar 2013 Location: Nottinghamshire Posts: 63 ![]() ![]() |
Did you have the engine running while you were using the IID Tool, as some on the warnings may be to with a low battery.
just wondering if its the abs sensor getting to hot and causing the errors, once it cooled down everything is ok... ... - .- -.
David: Yes, I had the engine running when I used the IID... Will check/read your link as well...
By the way, don't ask me how but since everything was reset, suddenly my passenger side mirror turns down when I reverse... And moves back in normal position when I put gear in Drive again. |
the dipping mirror can be sorted by moving the mirror selector switch..
Thx Stan, not annoying yet but will start to look into this next to sort it when it starts to become annoying... |
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 ![]() ![]() ![]() |
The Vehicle Dynamics fault will appear at the first sign of another issue on the CAN with an important ECU elsewhere flagging an issue.
WSIR, thanks for sharing... Learning something new everyday on this forum!! |
I have found that the suspension does not work until you have done the lock to lock with the steering wheel. You get loads of seemingly unrelated lights and errors showing, do lock to lock and the compressor should kick in. Previously..
